20 August 2019
+VIDEO That’s it – pilots are redundant. The US Air Force Research Laboratory and a company called Dzyne have successfully completed a two-hour flight of a Cessna 206 single-engine aircraft flown by a robot pilot, nicknamed ROBOpilot.
The full title of ROBOpilot is Robotic Pilot Unmanned Conversion Programme and the flight took place earlier this month at Dugway Proving Ground in Utah, USA.
“Imagine being able to rapidly and affordably convert a General Aviation aircraft, like a Cessna or Piper, into an unmanned aerial vehicle, having it fly a mission autonomously, and then returning it back to its original manned configuration,” said Dr Alok Das, CRI’s Senior Scientist. “All of this is achieved without making permanent modifications to the aircraft.”
Captain ROBOpilot is at the controls… this Cessna 206 was flown for two hours by the machine
ROBOpilot interacts with an aircraft the same way as a human pilot would. For example, the system ‘grabs’ the yoke, pushes on the rudders and brakes, controls the throttle, flips the appropriate switches and reads the dashboard gauges the same way a pilot does.
At the same time, the system uses sensors, like GPS and an Inertial Measurement Unit, for situational awareness and information gathering. A computer analyses these details to make decisions on how to best control the flight.
ROBOpilot is easily installed: remove the pilot’s seat and install a frame which contains all the equipment necessary to control the aircraft including actuators, electronics, cameras, power systems and a robotic arm.
4 comments
Has M.O.L heard about this yet?
What happens, on short final, after the computer freezes and takes 1 or 2 minutes to re-boot and ROBOpilot clutches the controls in a vice like grip, as you hurtle down to buy the farm?
By the way, from time to time, Teslas do this, and they have not yet figured out how to fix that.
For me the point of flying to to fly the aircraft, I would not even welcome an autopilot.
Ryanair looking to buy! Lol.
